heyhey :)
i got a question, an idea.... im spending more and more of my time producing hardcore techno acid house etc and vdj is perfect for mixing the perfected mp3 files, but further on down the line, when professional stuff may be (or not be) required (but still might be bought anyway so ner :P), using a maya usb connector is it possible to use an allehn & heath xone 62 mixer, maybe xp10's or cd/mp3 decks, and vdj? alot of 3 channel mixers have no problem, and theyre all fairly cheapish (around $450-$900AUS), and a couple have usb connectivity, but the xone 62 is a 4 channel mixer with 6 dual stereo inputs. does that mean you can just not connect one...?
and a few will say "at around $3kAUS youd have to be insane..." but any and all questions or problems of sound quality are settled with a mixer like this, aiming for the top never hurt anyone :P
geposted Fri 24 Jun 05 @ 2:53 pm
oh and ill have my full copy by about this time next week :)
geposted Fri 24 Jun 05 @ 3:03 pm
I'd suggest you get the XONE92 instead. It's more expensive, but a way better mixer. And it has MIDI which you can use to control VDJs effect, video crossfader or other nifty stuff...
geposted Fri 24 Jun 05 @ 10:18 pm
but it/they are definately connectable to pc/vdj?
geposted Sat 25 Jun 05 @ 12:41 am
not directly, there's no USB.. You still need the soundcard..
geposted Sat 25 Jun 05 @ 2:08 am
I have the Xone 92 - would you suggest a M-Audio Uno to connect the laptop to the mixer? Or is there a better solution?
http://www.m-audio.com/products/en_us/Uno-main.html
geposted Fri 10 Nov 06 @ 1:43 am
no love here -- huh
geposted Sat 11 Nov 06 @ 3:18 am
if its your intention to try and send midi signals to the pc
yes that will do
if you want to send audio you need a usb soundcard not a midi box
yes that will do
geposted Sat 11 Nov 06 @ 3:31 pm
thanks.
geposted Wed 15 Nov 06 @ 12:09 am
