As in if I extract them on a windows PC will I be able to use the same files? There aren't that many available for Mac!
geposted Mon 25 Oct 10 @ 12:27 pm
Unfortunately not.
Plugins for Mac have to be re-written. You cant use Windows effects.
Sorry
Sorry
geposted Mon 25 Oct 10 @ 12:31 pm
Guess I'll have to use it with my vmware w7 then :-(
geposted Mon 25 Oct 10 @ 1:10 pm
VMWare is a VM, so expect poor performance on your Win7...
geposted Mon 25 Oct 10 @ 1:44 pm
Poor is an understatement - it's really not designed for realtime audio purposes.
Bootcamp would be the better option for you.
geposted Mon 25 Oct 10 @ 3:35 pm
I can second that, I run my macbook bootcamped its the only way to run the windows version properly as it runs as a pc not emulated in any way.
geposted Mon 25 Oct 10 @ 5:12 pm
