Forum: Old versions
Topic: VirtualDJ & continuous playing
Hi,
I want to use my DJ Console RMX with the VirtualDJ DJC5 Software on a Party, but it is a private party with dinner and so on... There I will "play" the DJ but while the dinner I need a Continous-Playing function. So that the Software plays the tracks in the list one after an other without my influence...
But I couldn't find something like this...
Any Idea?
geposted Tue 26 Oct 10 @ 1:33 pm
Yes this is doable. This operation is called Automix. VirtualDJ basic feature. You will find all the infos in the PDF Manual.
Hi,
Sry, but I can find anything like this... I searched for it in the Software and in the Manual.pdf, but nothing like this... Is this function really available in the "Virtual DJ 5 DJC" Version??
I just checked the comparison chart and "Intelligent Automix Mode" is not included in the DJC edition.
The new free home version has this, but it won't work with your console :(
I suppose you could install both, use the home version for the playlist feature then swap over to the DJC version?
Please see the comparison chart here: https://virtualdj.com/products/comparison.html
Keith
Thx, I'll have a look on it...
Your Idea isn't so bad, but if I have to use an other Software to us the Automix-Function, I can also take an other Player an let him play a Playlist...
You could always upgrade to VirtualDJ Professional - This will allow you to use automix with your console, custom skins, effects and much, much more.
Your RMX DJ Console entitles you to a significant discount off upgrading to VirtualDJ Professional. To receive this, please go to https://virtualdj.com/buy/
