Just Boot Camped my Mac Book Pro with Win7, mini-port to VGA doesn't seem to be recognized. Any help with this would be much appreciated!!
geposted Tue 26 Oct 10 @ 7:16 pm
did you make sure you put your apple disc in and loaded all the extra drivers?? if so right click on the desktop and go to ATI control centre and run the wizard. it will expand your desktop on to the attached monitor. That should work. Im going off memory as i use MAC OS to run VDJ now that the AUDIO4DJ box is 100% supported.
geposted Tue 26 Oct 10 @ 8:59 pm
Just right click on any free part of your main screen, last option is personalize (or something I have my OS in spanish), a window will open. The last option is screen configuration, click and check the box to expand on the second screen. I have the configuration as you with win 7.
Good luck.
Good luck.
geposted Fri 29 Oct 10 @ 6:36 pm
The windows I loaded doesn't allow for display change no matter what I click on, just isn't there... nor is the Wi-Fi, its in some kind of basic mode and wont allow me to do anything.
geposted Sun 31 Oct 10 @ 8:16 am
Reason is I was in a hurry and didn't load the Mac OS disc while in Windows! Soooo, anyone reading this, if your'e thinking of running Boot Camp on your Mac do it! Its the best of both worlds and nothing runs windows like a Mac!
geposted Mon 01 Nov 10 @ 7:42 pm
