I have pair of 5500 and have yet to get it to work in midi. Thought i would give it a try with 7.0 which rocks with the denon 4500.
Have read the forum and made the adjustments in setup and using the lastest firm on the 5500's. I am using a PC with vista pro. Note the spinning platter is not a big deal to me i am not a scratch dj but want to use the decks for midi control of VDJ.
before trying to work a pair i tried to setup vdj with just one 5500 using the layers. Here are my issues:
1. when the platter is on in spinning mode and i press the play button there is a lag to the start button as the platter turns on. I can remedy this by turning the platter on.
2. When i try to use the 2nd layer with the platter on the speend seems wrong and sounds like chimpunks. When i turn off the platter the cue point seems to move. When in pause the song randomly plays for a few sec moving forward each time. I can see this on the pc screen yet nothing is being touched on the 5500.
Any help here would be great.
-TM
-TM
geposted Tue 26 Oct 10 @ 7:27 pm
Have the same problem. I've asked the support (a "ticket") and I'm waiting for an answer.
geposted Wed 27 Oct 10 @ 1:24 pm
Hey man, I used to own a pair of DN-HS5500 (My favorite Denon decks till this day) and I got them to work with VDJ 6, I remember there were some problems with the first version of VDJ6 not working right with the DN-HS5500s but it was fixed in later releases.
I do see one problem in your setup, you are using Windows Vista Pro and this was a problem for me.
It was suggested to me by another forum member to change to windows XP and it did the trick.
I remember us having a few threads on the forum about this, try using the search function to dig up the old threads.
geposted Wed 27 Oct 10 @ 4:57 pm
Thanks for the info guys. Hope there is fix soon.
geposted Thu 28 Oct 10 @ 3:34 am
