So i just installed VDJ7 and for some reason i can't get sonique and clipbank to work. Other videos and effects work fine but these two act as if they are empty even though i downloaded and installed Clipbank 1.2 and the 72 Sonique visualizations in the Video Effects folder.
I have tried putting the unzipped contents of the Sonique folder directly in the Video Effects folder and in a separate folder named Sonique. Neither work. Not sure what exactly is supposed to happen when i run the Clipbank install but so far it hasnt done anything.
Im running a desktop with Windows XP, 1.86Ghz Core 2, 2gigs of Ram and an nVidia 8800GT.
geposted Thu 28 Oct 10 @ 1:23 am
remember to have your vids stored where they are accessable for clipbank as they need to be in the same location each time you open up VDJ
for soniques
Go into config > choose video tab > go down to the bottom right drop down window and select sonique, to the left make sure you tick the box, come out of config and select effects > select video tab > select sonique > select/click on activate > select open > this is where you go to where you have your sonique folder, now open the folder and double click on a file, this will now run your sonique effects. you can now play with the two sliders for the type of effect you want. slide show delay will give you how long each effect will run for and the transparency will let you fade the soniques over other effects like a video, show logo etc...
N.B If you have the time go through your individual soniques and delete the crappy ones, saves getting them up on the screen.
geposted Thu 28 Oct 10 @ 4:52 am
