Here are my specs
Compaq Presario
500 GB HD, 100 GB free
2 GB RAM
Vista Home SP2
Using VD7
Numark NDX400 (using them as timecodes, not midi controllers)
Audio 4 DJ soundcard
DDM 4000 mixer
(side note too, have a cooling pad set up, but got the brilliant idea to plug the USB into a wall charger with a USB port, so it cools the lappy but not use a USB port or any additional power/resources)
So here's the questions I have -
Should I use the ASIO4ALL program in the Advanced Settings, or can I use the ASIO drivers in the soundcard? (I've run the DPC Latency Checker, and for the most part, either setting maintain a below 70 us rating, with a yellow spike here and there.)
With PureScratch being in VDJ7, the sound has never been better, however, looking at Scratch options, (Quality vs Latency) I'm a little confused as to what would be best to get the most real sound. For example, when you scratch, getting rid of that "digital" sound. I know VDJ and especially with CDJs, it's all digital, but is there a work around to this?
Last question
Does anyone else experience a loose feeling with timecodes? I've tried other CDJs, and I don't feel full control with them either, like some setting needs to be tightened to get better control of every movement.
Final final question - does anyone know how to set it so that if I stop a timecode, that the track in the deck goes back to the beginning? I can understand hitting Pause, but if I stop the track, and hit Previous Track on the CDJ and the timecode goes back to the beginning, that the track/deck act accordingly. I've done it before, just don't know what the setting is....
Sorry to sound like a newbie, just been searching the forums and can't find anything to answer these or I'm finding too many answers!
Keep up the good work, Dev Team!
Compaq Presario
2 GB RAM
Vista Home SP2
Using VD7
DDM 4000 mixer
Last question
geposted Thu 28 Oct 10 @ 7:06 am
Correction, NDX800s...it's been a long morning!
geposted Thu 28 Oct 10 @ 9:26 am
Did you check the community under the wiki and manuals link. they have a lot of useful information there.
geposted Thu 04 Nov 10 @ 4:18 pm
