Hello,
I´m testing VDJ 7 Trial and I´m asking myself if the following set up would be possible:
I want to use my Timecodes with my Hercules DJ Console MK2, that should be no problem for VDJ7 I guess. But now I want to route the output through "NI Guitar Rig", becuase of its nice effects. Would this be possible? Maybe via "Virtual Audio Cable"?
geposted Thu 28 Oct 10 @ 8:38 am
ur only gonna be able to use it for 10 mins
geposted Fri 29 Oct 10 @ 8:32 pm
Is anybody out there using a NI Audio 8 with VDJ 7 (4 decks), mixer & time code. If yes, how well does it work for you?
Right now I'm using VDJ 7, a Behringer ddm4000, one Denon DN-S3700 & a Numark Virual Vinyl I/O box. It works fine
but the I/O box only has 3 stereo outs so I can only control 3 decks with timecode. I'm thinking about buying a new audio card
and the NI Audio 8 seems like a good choice but I'd like to know if anybody is using a similar set-up and get some reviews
before I go and spend my money...
geposted Fri 29 Oct 10 @ 10:38 pm
Just got one today so ill post more tomorrow but so far it sounds great.
Huey
Huey
geposted Fri 29 Oct 10 @ 11:49 pm
