A family member of mine recieved the Ion Discover DJ as a gift. She doesn't like the program it came with. I have used your programs and was wondering if Virtual DJ is compatible with Ion Discover DJ? Thank you for your time!
geposted Thu 28 Oct 10 @ 3:52 pm
You're in luck.
Virtual DJ 7 fully supports the Discover DJ. However, if she's downloaded VDJ Home, it will only work for 10 minutes. Buying the software will let her use it for as long as her heart desires.
geposted Thu 28 Oct 10 @ 7:42 pm
which virtual dj package do I have to buy to use the Ion discover decks?
geposted Sun 21 Oct 12 @ 9:42 am
For all controllers the answer is the same - LE version if included with controller, otherwise Pro Full would be required.
geposted Mon 22 Oct 12 @ 3:45 am
