Cannot get my crossfader to work at all. Any suggestions on what to try? Thanks
geposted Sat 30 Oct 10 @ 9:27 pm
I know it's probably too late now but did you check your settings? I will try to cover everything so you have it set up correctly.
If you are running VDJ7 with 4 decks make sure you have the VMS4 set to 8 out - not 4 out.
In Sound Setup make sure you select advanced configuration and set up as follows:
For Mac:
Deck 1 VMS4 Audio Midi Device Output 1 & 2
Deck 2 VMS4 Audio Midi Device Output 3 & 4
Deck 3 VMS4 Audio Midi Device Output 5 & 6
Deck 4 VMS4 Audio Midi Device Output 7 & 8
For PC:
Deck 1 ADJ ASIO Driver Output 1 & 2
Deck 2 ADJ ASIO Driver Output 3 & 4
Deck 3 ADJ ASIO Driver Output 5 & 6
Deck 4 ADJ ASIO Driver Output 7 & 8
Make sure these lines are set to USB and not ANALOG.
Using the crossfader is not ideal when using 4 decks but you can still assign which deck you want to control with the line select switches in front of the unit.
_____________________________________________________________________________________________________________
If you are running VDJ7 with 2 decks make sure you have the VMS4 set to 4 out - not 8 out. Also, line select should be line 2 for channel 2 and line 3 for channel 3. Make sure these lines are set to USB and not ANALOG.
In Sound Setup select the VMS4 as your Sound Card for Mac and PC.
More information at the American Audio VMS4 Discussions
Hope this helps.
For Mac:
For PC:
Hope this helps.
geposted Sun 31 Oct 10 @ 8:29 am
Thanks koz. I'm laying in bed thinking about it now I know what it was. The crossfader knob was on the wrong setting. The smallest thing always bites me in the ass. Its only my second time using it since it came out. Wish I would have thought of it last night.
geposted Sun 31 Oct 10 @ 8:40 am
Glad you were able to figure it out.
geposted Sun 31 Oct 10 @ 2:30 pm
