Ok, I'm trying to code my first VER.7 skin and I am having a hell of a time with the rhythmzone function.
I've got the waveform functionality working, it displays the waves and cues and cuepoints etc.
However, if I use the command in my XML, all of my play, cue, pause, sync buttons STOP functioning
I have been scratching my head with this for hours....
please, what am I missing????
DjChuck
*edit*
And I also can't get the dropzones for decks 2 or 3 to work either
and can you only dislpay 2 preview video's?
Why don't they give more detailed information in the skin sdk?
I'm grumpy, i'm gonna stop typing now
DjChuck
DjChuck
*edit*
DjChuck
geposted Mon 01 Nov 10 @ 1:53 am
Post here the rhythmzone part of your xml. It would also help to post a screenshot and the resolution you make the skin.
geposted Mon 01 Nov 10 @ 4:52 am
I've PM'd you my email address. Send me the XML file and I'll take a look for you!!
I will send you the XML when I get my laptop open.
I want to clarify though... I can get the rhythymzone component to work just fine
What's happening is.. If I use the rhythmzone command instead of
The old rhythm command, I lose the functionality of my play/cue buttons
Keyboard shortcuts and mix_now_nosync button works also
Was wondering if anyone else was having similar issues at first and knew what was causing it.
Will post the XML shortly... It's not complete yet but I'll post what I have.
Will also email you the file.
DjChuck
DjChuck
geposted Mon 01 Nov 10 @ 11:40 am
Quote :
<Skin name="CB Graphix VDJ 7 Quad Deck Spacesaver" version="1" width="1366" height="768">
<copyright>- (c)2010 - CB Graphix -</copyright>
CHANGE THE VERSION TO "700" - does this fix the problem??
N.B. the version must the be the version of Virtual DJ - not your skin version. 700 represents 7.0.0 - the current version.
geposted Mon 01 Nov 10 @ 1:59 pm
never mind, it's fixed now...
DjChuck
DjChuck
geposted Mon 01 Nov 10 @ 2:03 pm
I will try that... brb
geposted Mon 01 Nov 10 @ 2:05 pm
I knew it was something simple... yes, that absolutely fixed it.
blush
Thanks.
blush
Thanks.
geposted Mon 01 Nov 10 @ 2:07 pm
lol, i still can't load decks 3 and 4 though... and I changed the y coord to get rid of the overlap too..
geposted Mon 01 Nov 10 @ 2:10 pm
Good stuff!!
I'll look at that part of your XML now!!
EDIT:
Change chan="X" to deck="X"
EDIT 2:
You also need decks="4" in this top section - as illustrated in the quote.
EDIT:
Quote :
******dropzone*************************************************************************************************
<dropzone chan="1">
<size width="570" height="187"></size>
<pos x="0" y="57"></pos>
</dropzone>
<dropzone chan="2">
<pos x="796" y="57"></pos>
</dropzone>
<dropzone chan="3">
<pos x="0" y="243"></pos>
</dropzone>
<dropzone chan="4">
<pos x="796" y="243"></pos>
</dropzone>
<dropzone chan="1">
</dropzone>
<dropzone chan="2">
</dropzone>
<dropzone chan="3">
</dropzone>
<dropzone chan="4">
</dropzone>
EDIT 2:
Quote :
<Skin name="CB Graphix VDJ 7 Quad Deck Spacesaver" version="700" decks="4" width="1366" height="768">
that's a helpfull tidbit... things that they need to add to the WIKI. LOL, thanks
DjChuck
EDIT
And... it still does'nt work... sigh
DjChuck
EDIT
geposted Mon 01 Nov 10 @ 2:34 pm
NBDECKS="4"
now it works
now it works
geposted Mon 01 Nov 10 @ 2:43 pm
yeah sorry - thats right.
geposted Mon 01 Nov 10 @ 2:57 pm
