Ever since I installed get.7 on my 2 systems, vdj doesn't't see the random video transition plunging. Upon starting vdj I get an error saying no video transition found. Verify that the video transitions are in .\plunging\video transitions. It's not in documents/virtual/plunging/video transitions as the message stated. I double clicked to install the plunging again, but still nothing. I did a search and found it in the video effect folder. I copied it and pasted where it should be. I can see it now in the folder, but upon restarting vdj , it still doesn't' see it. Is the random video transition plunging not comparable with vdj7?
geposted Tue 02 Nov 10 @ 10:44 am
I just tried on my Vista system, and you are right. However, I did not have this issue when I first installed 7. I wonder if a recent Vista update changed something. I will check my gig machine which is XP when I get home, but I think everything worked OK during my Halloween Party. Now that i think about it, I don't really look at the videos that much when I'm mixing.
geposted Tue 02 Nov 10 @ 6:32 pm
The actual random transition plugin should be in the VideoEffect folder as that is what it is. I've just tested it on my machine here with VDJ7 and Windows 7 and it works fine.
The error you are seeing occurs when the random plugin can't see any transitions. The transitions themselves should all be in the VideoTransition folder - you might want to verify they are still there!
To summarise:
The VideoEffect folder should contain: RandomVideoTransition.dll
The VideoTransition folder should contain the transitions such as alpha.dll, cube.dll and so on.
Do you see any transitions listed when you click Transitions in VDJ?
To summarise:
geposted Tue 02 Nov 10 @ 7:43 pm
I've just had a look at the source code for this plugin and can see a potential issue; I'll contact djcel and let him know.
geposted Tue 02 Nov 10 @ 7:48 pm
Thanks SBDJ. Let me know what he says.
geposted Tue 02 Nov 10 @ 8:00 pm
Just as I suspected, I do not have this issue on my gig machine, which is XP. As stated before, I did not have this issue when I first installed on my Vista machine. The transitions are in the transition folder, so do not understand what went wrong. Maybe I will re-install 7 to see what happens.
geposted Tue 02 Nov 10 @ 8:58 pm
Any word from djcell on this issue?
geposted Sun 07 Nov 10 @ 1:49 am
He's currently on holiday I'm afraid.
geposted Sun 07 Nov 10 @ 10:16 am
I'm back and I have just added it to my TODO list
geposted Sun 14 Nov 10 @ 7:34 am
Any new word on the Random Video Transition.
I installed it on mine and it does not come up in my video transitions..
geposted Mon 11 Apr 11 @ 11:52 am
Random Video Transition shows up under video effects because it is an effect that randomly selects a transition ;)
geposted Mon 11 Apr 11 @ 4:40 pm
