If anyone here could help as i am new to this, is there a way to get the itunes visualiser working in virtual dj? Any ideas as it would be the best thing ever?
geposted Tue 02 Nov 10 @ 3:30 pm
Nope.
geposted Tue 02 Nov 10 @ 3:48 pm
thanx:) guess just stick with clipbank
geposted Fri 05 Nov 10 @ 2:52 am
Clipbank is ONLY for PC correct? Does Mac have anything similar?
geposted Fri 12 Nov 10 @ 2:06 am
Clip bank works on both platforms. Finding great content is the tricky part lol.
geposted Mon 09 May 11 @ 2:47 am
Actually...if you really REALLY want to, you can make iTunes visualizer react to VDJ, but it's somewhat tricky.
iTunes visualizers are Quartz compositions, so you'd have to install the XCode developer tools, open the preferred iTunes visualizer to Quatrz Composer and tweak it's settings to react to, say, line-input coming out of your mixer's main channel.
I've tried this few times with Quartz compositions I made myself, so it should work in theory. Making visualizers with Quartz Composer is not very hard especially if you have any programming experience, plus there are tons of ready-make Quartz compositions freely available.
geposted Tue 10 May 11 @ 4:12 am
I was thinking about the possibility of implementing a ProjectM plugin for the Mac....
geposted Tue 10 May 11 @ 10:01 am
I like the sound of that!! Are you thinking something along the lines of a beefed up Sonique style plug-in for mac?
geposted Sun 29 May 11 @ 10:56 pm
No, I was thinking about ProjectM - an expanded port of Milkdrop. It would be a fairly large undertaking though and really isn't high up on my priority list.
geposted Mon 30 May 11 @ 4:20 am
