Gang -
How would I setup ASIO while the advanced setup is open?
There is no way to easily get to it w/o selecting ASIO in the sound card options.
All I can do is assign sources to outputs.
Is this by design or just overlooked?
Thanks!!!
Thanks!!!
geposted Tue 02 Nov 10 @ 11:10 pm
What type of card are you using and didnt you already ask this question?? For me I use the Audio DJ 8 and I can acess the settings by going through the start menu blah, blah, blah.......
Before I ran into the same problem with the Maya44 so I just changed the settings before going into the Advanced Config and it was all good. Reading your previous post I'm sure your not gonna want to do it this way but it works...............
Huey
Huey
geposted Tue 02 Nov 10 @ 11:35 pm
