When assigning browser_zoom to a keyboard shortcut key (like F11, or Shift+F) the function performs normally the first time, but then VirtualDJ seems to lose its focus so that keyboard shortcuts do not work until the skin is clicked on again.
This seems to be a bug in VDJ7
I'm under Windows 7 64bit.
geposted Wed 03 Nov 10 @ 4:44 pm
Is there a fix for this??
Huey
Huey
geposted Sun 15 May 11 @ 12:32 pm
same problem with w7 64 bits
geposted Thu 18 Aug 11 @ 9:26 am
It works for me, I dont what has changed but I can switch back and forth with my controller now.
Huey
Huey
geposted Thu 18 Aug 11 @ 10:58 am
The above shortcut works and always worked if assigned to a controller button. There is an issue when you assign that on a keyboard button. Hopefully it will be fixed in next versions.
A workaround is to press enter after the shortcut.
geposted Thu 18 Aug 11 @ 12:07 pm
