I was using my 4500 with 6.02 perfect. Just tried 7 and the controller is recognized but the buttons don't do anything, only the song info is displayed when a song loads. Tried going back to any of the vdj 6's, and it won't recognize the controller at all.
using XP
PLEASE HELP!
using XP
PLEASE HELP!
geposted Wed 03 Nov 10 @ 11:51 pm
Do you have the latest firmware installed from http://www.denondj.com/firmware.aspx?ProductId=81 ?
geposted Thu 04 Nov 10 @ 7:27 am
Yes i have the latest firmware.
Either way, somehow i fixed it. Don't know what i did. Between the multiple re installations of programs and drivers, it started working again. I guess it's still worth pointing out that when i installed vdj 7... the HC4500 got all wacked. For now i'm sticking with 6.
thanks for the quick response.
geposted Thu 04 Nov 10 @ 9:20 am
I have the same problem with Cue and my Denon 3700's, I was using 6.*.* without a glitch until I upgraded everything, now nothing works! I am glad you were able to fix your issue, I am getting extremely frustrated with mine.
geposted Thu 04 Nov 10 @ 1:51 pm
i have no problems with my hc4500 and vdj7. works great.
geposted Thu 04 Nov 10 @ 4:09 pm
There is no difference between V6 & 7 as far as controllers are concerned. Both versions use the same mapping script and the transition should be totally seamless,
geposted Thu 04 Nov 10 @ 5:07 pm
