Hi everyone.
I am using latest version of virtual dj but there is something I would like to know. When clicking the config button and going into the options screen I see Jog Sensitivity scratch, cue & bend by sliding these sliders would they affect the HC4500 jog wheels, As cueing using the jog weels on controller are really slow. Thanks
geposted Thu 04 Nov 10 @ 5:45 am
Yes, these options affect the sensitivity jogwheels on a MIDI controller.
Try setting the cue sensitivity to the same as the scratch.
geposted Thu 04 Nov 10 @ 1:23 pm
Check the Denon hardware section. It has all the settings you'll need to set up.
geposted Thu 04 Nov 10 @ 9:34 pm
