WHEN USING 4 DECKS HOW DO YOU AUTO MIX FROM DECK TO DECK IS IT THE SAME AS DJMIXSTATION 3
geposted Thu 04 Nov 10 @ 6:50 pm
Sorry, dual deck automix is depreciated since VirtualDJ v4 and has been long since replaced with a more powerful single deck system that has more flexible automixing options. It also leaves the other deck spare, allowing you to cue up a song ready for when you wish to take over mixing manually again.
However, you can map a keyboard shortcut or MIDI button to the action automix_dualdeck which will allow you to enable dual deck automix again, however this is depreciated and is not recommended. Pressing the key will turn on the dual deck automixing and pressing it again will revert to the new single deck automix.
geposted Fri 05 Nov 10 @ 6:51 am
