For some reason, the key lock doesn't work in VDJ7 for me. When I hover over the padlock, deck 2 key_lock, and click it, nothing happens. Anyone have this issue?
Thanks in advance!
Also, is there a way to have an auto mailer sent when someone replies to a post. I looked around and couldn't find anything
Thanks in advance!
geposted Fri 05 Nov 10 @ 9:00 am
Turn on "Safe Mode" for the keylock and look above this post you'll see a bell. Click on the bell and when someone replys it'll let you know.
Hope this helps
Huey
Hope this helps
Huey
geposted Fri 05 Nov 10 @ 9:14 am
Thanks Huey. I've been using this software for a while but I'm just getting acquainted with the forums. Thanks for your help!
geposted Fri 05 Nov 10 @ 9:30 am
No prob, were all still learnin bro!
Huey
Huey
geposted Fri 05 Nov 10 @ 9:49 am
In VirtualDJ v7, make sure that you do not have CONFIG -> Performances -> PureScratch selected.
Keylock/master tempo cannot be used with this option.
Choose either Advanced Stretching if your computer is fast enough or Fast Stretching otherwise.
geposted Fri 05 Nov 10 @ 12:40 pm
