I noticed that at the bottom of the Hercules alien screen (where u change from Normal mode to DJ mode) that at the bottom is a checkbox which says "enable dj mouse"...
What is this? I've not been able to figure it out... Anyone know? I've searched the forums (hardware, software and general) but couldnt find anything on it. Have i missed a thread?
Nebula
Nebula
geposted Sun 26 Jun 05 @ 2:48 pm
Well, i never use it but.. In settings (green alien head) there is to set MIDI input. If you set to "MIDI-In plug" (not to "DJ Console buttons"), then you can use your joystick on your console like mouse, so you can use it to move cursor on screen and under joystick are 2 buttons - left & right click.
Dj Nikki
Dj Nikki
geposted Sun 26 Jun 05 @ 8:50 pm
Ah rite, Ok cheers :o)
geposted Sun 26 Jun 05 @ 11:00 pm
