I have two problems. My head phones are not working with the MAC. Also the jog wheels are not responding well not making me able to cratch. Please help
geposted Sat 06 Nov 10 @ 12:43 pm
Make sure that your sound settings are as follows:
Outputs: Headphones
Sound card(s): 4 out card
Sound card: Typhoon
Click APPLY.
Next, make sure the CONFIG -> Options -> Jogmode is set to Vinyl - There is no scratch toggle button on the Typhoon.
You may also need to configure it in MacOS for 4 channel audio:
Outputs: Headphones
Sound card: Typhoon
Click APPLY.
- Open the Utilities folder inside your Applications folder. Double-click on Audio MIDI Setup.
- In the Properties for: drop-down, choose the Typhoon.
- In the Audio Output section, choose 4ch-16 bit.
geposted Sat 06 Nov 10 @ 2:31 pm
