anybody else have this problem....its a crash at random moments ....but a good way to tell if it will crash on you is by playing a video and using the effect text2d turn it on just once and leave it on or turn it off if you want it doesnt matter....then shut down virtual dj by click on the "X" just like closing any other program or window....then right after vdj shuts down it will give you a crash notice it does this evry single time i use text2d....of course thats not a problem if it only does it when you shut down vdj....but it will randomly crash while playing..it just shuts down...its sad because thats a very cool plug in i like it more than sbdj scroll text because you can use different fonts from one message to the other....anyways ive tried other effects and none other have this problem....im pretty much trouble free and have had minimum problems zero crashes while playing i play videos all night with a max of 18% cpu usage 40% memory usage on a dual core 2.00 ghz 3gigs ram sony vaio i use all 4 decks on video at the same time and zero problems just this one effect....im almost sure there is something wrong with that effect.
geposted Sun 07 Nov 10 @ 2:22 am
I got the same Problem with VDJ 7.0.1 and SBDJ Scrolltext bei loading a saved text, the windows not close and on the Beamer i have only gray while the music is continouing to play.
I have cleaning the complete VDJ 7 installation of recomendation with a German Moderator here and going back to Version 6.1.2 until the problem is solved on Version 7
Mike
Mike
geposted Fri 10 Dec 10 @ 2:56 pm
No-one else experiencing that problem with VDJ7 and ScrollText as far as I know. It's the first I've heard of it!
To the OP: Video plugins are only available to pro users...?
geposted Fri 10 Dec 10 @ 9:55 pm
