hi,
When i download a skin and i will run it. It says; VirtualDJ not found
But i already install virtualdj.
Last month i had a map in my documents called Virtu and then some strange signs but now i installed again and is gone.
geposted Sun 07 Nov 10 @ 12:47 pm
Maybe you tried to install a skin which did not match your VDJ version ?
Greets, Heiko
Greets, Heiko
geposted Sun 07 Nov 10 @ 1:00 pm
And how i see that?
geposted Sun 07 Nov 10 @ 1:34 pm
On the skin page you see for whitch version the skin is created for. I think your LE Version is v3.4 or 3.41 if i remember correct.
You can not use skins created for version 4, 5, 6 or 7.
Greets, Heiko
Greets, Heiko
geposted Sun 07 Nov 10 @ 1:43 pm
