Ok I figured that if I use the registry tool I can force default sort to "23" which is Key(numeric).
I want to make a browser_sort "XXX" button for this but, browser_sort "Key(numeric)" does not work.
I looked in the wiki and it only identifies numbers 2 - 19.
I also tried browser_sort "camelot" because of what I found in the skin .xml
Does anyone know what syntax would be used?
Thanks!!
Thanks!!
geposted Sun 07 Nov 10 @ 7:43 pm
OK you can use "browser_sort "key" even if you have "key(numeric) showing in your browser it'll still sort them.
Hope that helps
Huey
Hope that helps
Huey
geposted Sun 07 Nov 10 @ 8:20 pm
browser_sort "keynumeric"
geposted Sun 14 Nov 10 @ 5:59 am
DJCel...Thanks!!
geposted Sun 14 Nov 10 @ 12:25 pm
