Hello......
As you can tell this is my first post to your forums but I really really wanted to stop by and give you a huge "thank you" for this awesome plug in. So thank you thank you thank you!
I started DJ'n at a private club that already had Virtual DJ a couple years ago and after being asked to do some other venues went out and purchased a pile of DMX lights. Freestlyer was a bit of a challenge to get up and running but now I have the hang of it and this plug in dropped right in.
Ur friggin' awesome!
geposted Thu 14 Apr 11 @ 2:24 pm
Yes, completely agree!! Stoked to hear you are still making improvements to this plugin SBDJ. I dont think people understand what a difference this can make to the quality of the lightshow.
Wish I could find a way to keep a freestyler cue panel open over the vdj screen though - this alt tab thing to find blackout or change cues is too much work ;)
geposted Thu 14 Apr 11 @ 2:29 pm
You won't have to worry about that soon - you will be able to control those things directly from VDJ as shortcuts - so keyboard, MIDI and skin.
geposted Fri 15 Apr 11 @ 10:34 am
That would be the final piece of the puzzle. Well done mate!
geposted Tue 19 Apr 11 @ 4:20 pm
Here is a short vid from a wedding last weekend. It is so easy now not having to change the tempo using my controller and one less piece of hardware on the table. I only have a couple of simple chases programmed in freestyler but you can see the led par cans reflecting on the back wall in perfect time to the music. This has been impossible with every sound to light software I have tried. Cant thank you enough SBDJ - surprised more djs havent been interested in this.
geposted Fri 22 Apr 11 @ 12:57 am
