Hi there,
I am using Windows 7 with the following Sound Blaster SE card
http://us.store.creative.com/Sound-Blaster-Audigy-SE/M/B000LP0R3E.htm
My speakers is an old set of Cambridge FPS 2000, consisting of 4 speakers and 1 subwoofer.
I usually have the speakers plugged into the green and black slots of the soundcard, which seems to work ok. I started using Virtual DJ Pro 7 and have problems getting both my headphones and all four speakers to work properly. It works "ok" when I unplug the speakers from one of the slots (e.g. have the speakers only plugged into the green OR the black slot) and then plug the headphones into the green slot for instance.
What I am basically trying to achieve is to have all 4 speakers play the current song (just like when listening to music) and use my headphones to cue up the next track.
I would really appreciate any help as I have spent hours online trying to find a solution. Thank you so much!!!!
geposted Mon 08 Nov 10 @ 2:58 pm
