Hey Guys,
Just wondering about peoples experiences of the Xone 3D and Virtual DJ? Been pricing them up recently, and wondered if they are compatible with 4 decks in VDJ 7? Also what are peoples experiences of mapping them etc.
Regards,
Adam.
Regards,
Adam.
geposted Mon 08 Nov 10 @ 6:46 pm
They are awesome for VDJ and 4 deck setup is a breeze. The 3d has a 4 channel soundcard but VDj can be mapped to use 3 from the 3d and 1 channel from your laptop.
The 4d has 4 channels.
Mapping is easy aprt from the jo wheels if using the simple midi commands or there is a mapper in the downloads section that can be modded easily enough.
Aprt from the 4th channel on the 4d no reall difference between the 2.
Sound and build quality is top notch as you would expect from Allen & Heath
geposted Tue 09 Nov 10 @ 4:46 pm
