Hello, now that it seems like the vdj7 can read and display itunes playlists, can the same be done with MediaMonkey? I prefer it to Itunes for several reasons, but from what I have seen, vdj7 does not display the MediaMonkey playlist.
geposted Mon 08 Nov 10 @ 8:03 pm
Mediamonkey does work with VDJ7 use export to playlist on your desktop and it creates a standard M3U format playlist works every time. Look to the file folder location you saved your MM playlist and you can import them.. BTW MM is far more powerful than Itunes and will work with every device that supports the standard Playlist format.
geposted Mon 08 Nov 10 @ 8:22 pm
Thank barney the flexibility and compatibility of MM is what I love about it.
geposted Mon 08 Nov 10 @ 9:01 pm
I'm an avid MM fan as well and that it what I do. I export the playlist right to the VDJ Playlist folder.
Cheers,
Roy
Cheers,
Roy
geposted Thu 11 Nov 10 @ 9:29 am
can anyone help me with a problem im having with vdj7?
for some reason its not picking up my itunes library.
if any help could be passed on it would be amazingly grateful.
thanks
thanks
geposted Wed 08 Dec 10 @ 9:39 pm
