hey guys. well as you would already know, im new to virtual dj.. was just wondering.. why is deck a playing out the right speaker and deck b out the left? how can i make it so they both play out.. both?
geposted Mon 08 Nov 10 @ 9:15 pm
You have probably chosen the Mono Split option without using an appropriate splitter cable to split the left and right outputs for master and headphones.
To be able to pre-listen to music using headphones, you will ideally need two sound cards or a sound card with multiple outputs, such as a 5.1 surround sound card or preferably a dedicated DJ sound card (E.g: Numark DJIO.)
With a laptop, you can add a USB stick sound card that will provide you with the additional output that you need.
Alternatively, you can use a single sound card and the mono split option in VirtualDJ's sound setup, however this will only give you MONO sound. You will need a splitter cable to split the left/right channels - Please search Google for: 3.5 jack splitter to mono
geposted Tue 09 Nov 10 @ 2:56 am
