Hi, I'm new to Djing, just really been messing about on VDJ and Traktor, and I wanna start using a controller as well. From reading reviews and forums I think the best controller seems to be the Vestax VCI 100, but is it worth the extra money for the mark 2 with the built in sound card? The standard VCI 100 retails at £369.99 and the Mark 2 retails at £399.99. Thanks :D
geposted Wed 10 Nov 10 @ 5:21 pm
Well, what sound card are you gonna use? The MK2 and others have the sound card built in. Less to plug in, they are compatible with each other. If you already have a sound card that you like, then you have your answer. You may want to do a little more research, because I don't know if it is the best controller. You need to find the controller that works best for you. Good luck.
geposted Wed 10 Nov 10 @ 5:55 pm
