Hey, I just started using the free home edition of Virtual dj and im loving it. Im pretty much a begginer at allof this stuff, i can do basic mixes and whatnot, but a little advice would be much appericiated. Im also wondering if i should get some controllers? If i should get some where and how much will they be? Thanks.
geposted Thu 11 Nov 10 @ 10:46 pm
There are controllers ranging from $150 to thousands. Depends on your budget and what you want to do. Some come with the LE version of VDJ but home won't work with controllers so you may have to upgrade to Pro depending what you get.
Keith
Keith
geposted Fri 12 Nov 10 @ 12:56 am
don't know if you've visited this page but the wiki is very useful.
https://virtualdj.com/wiki/
geposted Fri 12 Nov 10 @ 9:03 am
Start cheap if you aren't sure.
Like with the DJ Control MP3 e2, it's only $100 then you can decide from there to spend more money for full licence and or move up to a better controller. I started withthe RMX, there is no turning back now.
geposted Fri 12 Nov 10 @ 11:37 am
The RMX is a great controller.I have lots of fun with it..
geposted Mon 15 Nov 10 @ 11:15 am
