I been a VDJ user on PC for about 4 years now. I normally run VDJ with a denon HC4500 midi controller. I may get into video here soon and will probably upgrade the controller and mixer to a Denon MC6000 when its released.
Also thinking about a new laptop.
My question is will a loose anything if i go Mac?
geposted Fri 12 Nov 10 @ 4:20 am
I changed from PC to Mac a few month ago.
At the moment it is for me the best OS for DJING.
But you loose the freedom to use the big range of Windows Products.
OK, you can use Bootcamp to run Windows Products on your Mac, but i didn't like that idea ;-)
So i use both.
So i use both.
geposted Mon 15 Nov 10 @ 7:08 am
I just got a mac and I'm getting used to it. Doesn't seem to be much different. All the stuff is pretty much the same except it is located in different places and called by different names.
I recently got a Hercules RMX and it does everything. Mixes music and video. The only thing I don't like about it is the mic has no eq. So I use
geposted Mon 15 Nov 10 @ 3:59 pm
