i downloaded the trial and it wont open it keeps saying sumthing about kernel32.dll
geposted Tue 28 Jun 05 @ 1:42 am
(re)install DirectX9.0c before.
geposted Tue 28 Jun 05 @ 9:16 am
This is the link to download:
http://www.microsoft.com/windows/directx/default.aspx?url=/windows/directx/downloads/default.htm
geposted Tue 28 Jun 05 @ 9:19 am
True, it wont open without directx 9 installed and optimised.
geposted Tue 28 Jun 05 @ 4:31 pm
Hey
Iv been having this problem with virtual dj for a few days now.
When i clikc on the virtual dj icon on my desktop a window comes up i press run and it opens the virtual dj bit and then an error message comes up saying directx sound driver error. I clcik ok, and then it the little error window will dissapear affter i click ok, and then the virtual dj loading part just stays still and doesnt load or open, i dont know whats wrong with it :( :/
Can anybody help me ??
I really need to fix it so i can keep mixing :)
Cheers. Ross
Cheers. Ross
geposted Mon 23 Aug 10 @ 9:59 am
It simply means you have changed the sound setup since you last played, just go to config > sound set up and adjust the settings to suit.
Digging up a post from five years ago must be hitting some sort of record.... lol
geposted Mon 23 Aug 10 @ 2:38 pm
i have same problem. I have virtual dj 4.2 pc version with the dj mk2 hercules sound card. I cant go to config though because the program isn't starting. I have the mk2 console connected to the pc and when i open virtual dj program the direct x error pops up and then I click ok it just shuts the program off. I cannot go into config to change the sound setup in the program settings or config. Please help
geposted Wed 22 Sep 10 @ 10:11 pm
