Hi there,
I have Numark Stealth controler and VDJ Pro ver 6.0.7.
I am trying to map certain buttons of the controller to my liking. For some reason, I cannot get the "KEY" button of each Deck to display Elapsed and Remaining time respectivelly in the VDJ interface.
I have tried different variations of display_time command:
display_time 'elapsed,total,remain'
deck 1 display_time +1
deck 2 display_time +1
deck active display_time 'elapsed,total,remain'
display_time "remain"
...and so on.
I have tried other keys (BEATLOCK) with these commands.
I have reverted back to default skin just to see if it solves the issue.
Nothing works. I just cannot get a button to toggle through Elapsed-Remain time display...
Please help,
Thanks
...and so on.
Please help,
Thanks
geposted Fri 12 Nov 10 @ 11:16 am
Try:
display_time "elapsed,total,remain" +1
geposted Fri 12 Nov 10 @ 9:51 pm
Here is an answer i got in Numark Hardware support forum:
Where do you want the time to be displayed? Numark Stealth has no digital display, so the only way is to be displayed on screen. To be displayed on screen and toggle between these times, the skin must support such a function.
Usually skins use textzones to display times, so you will have to modify one of them.
For further assistance please open a thread at the Skins Forum.
Posted a topic in the Skins Forums. Thanks!
geposted Sat 13 Nov 10 @ 5:32 am
Sorry, didn't see Stealth Control - I thought you were using a controller with a time display such as Numark DMC-2, Denon HC-4500, etc.
geposted Sat 13 Nov 10 @ 11:41 am
