Hello, I am an internet DJ, and still trying to figure out how to use my headphones with my hercules rmx. I use the PC speakers, they are connected to the back of my computer. My hercules is connected to a usb port in my computer too. Everything works fine, exept I can never figure out how to pre listen with my headphones. I am guessing there is no way to configure it so I can hear through my headphones what I want to cue, and have the main speakers playing? I am not a PC wiz, any help would be awsome, ty for the help.
geposted Fri 12 Nov 10 @ 1:46 pm
if im not mistaken. you should have your settings as
input-none
output-headphones
soundcard-hercules rmx
with the speakers using your computer soundcard and not your herc soundcard, im not sure if it will allow..have you tried running the speakers from the herc?
input-none
output-headphones
geposted Fri 12 Nov 10 @ 1:49 pm
I have tried everything. lol. and it iether runs thru the headphones, or the speakers. never both. Basicly I want to play thru the pc speakers. And hear what is playing next.
geposted Fri 12 Nov 10 @ 1:55 pm
I have tried everything. lol. and it iether runs thru the headphones, or the speakers. never both. Basicly I want to play thru the pc speakers. And hear what is playing next thru my headphones.
geposted Fri 12 Nov 10 @ 1:56 pm
ur PC speakers shoudl be connected to ur master out of ur rmx, since you are using the rmx as a soundcard.
geposted Sat 13 Nov 10 @ 4:06 pm
