Hi everyone.
I had a gig last night using the latest version of VIRTUAL DJ PRO 7 with Denon HC4500. This is whats happening everytime i load a track into virtual dj the pitch slider would automaticly change and match the beat of the playing track. So i went into virtual dj settings and turned it off, so upon loading the next song everything seemed fine to only find that when you cued up a song using hc4500 and you pushed play again the pitch slider in virtual dj would change and keep doing it for every song i loaded. songs would either speed up or slow down so again i went into the settings and turned everything off hoping that it would fix it, but to only find the denon controller was still doing it. I have a party tonight so i do not want it to happen again. Any help guys please.....
geposted Sat 13 Nov 10 @ 2:12 am
Getting desperate guys please help
geposted Sat 13 Nov 10 @ 7:24 am
I cannot believe this not one reply to my question looks like i will have to use 5.21 version :(
geposted Sat 13 Nov 10 @ 11:08 am
just guessing here mike but sounds like a short cut has been activated.
geposted Sat 13 Nov 10 @ 11:18 am
Possibly beatlock has been activated?
In earlier versions of VirtualDJ, this was mapped to B and was very easy to activate by accident. Check your keyboard mappings and change this mapping to something safer such SHIFT+B or delete it.
Also, make sure that the auto pitch matching and pitch reset on load options are disabled in VirtualDJ's options.
geposted Sat 13 Nov 10 @ 11:50 am
Probably worth setting beatlock reset to OnLoad in the options too.
geposted Sat 13 Nov 10 @ 12:58 pm
