Hi !
avec VDJ-7 je souhaiterai conserver mes BPM et CUE de mes MP3.
With VDJ 7 I'd like to keep BPM and CUE point of my MP3.
Is it possible to move database from my PC to my Laptop, and keep information about MP3, even if the MP3 are not on the same hard drive/folder ? (but have the same name).
Thank you very much !
geposted Sat 13 Nov 10 @ 8:50 am
yes just copy a copy of your .xml file to your laptop
geposted Sat 13 Nov 10 @ 9:04 am
Make sure that you put your music in exactly the same location on your laptop, e.g: If it is C:\Music on your desktop, then it needs to be C:\Music on your laptop too.
If you use external hard drives, these have their own database, so you don't need to do anything for them.
geposted Sat 13 Nov 10 @ 12:29 pm
exactly but when xml is updated id also put a copy on root of external hd
geposted Sun 14 Nov 10 @ 10:09 am
