Just done sound check, and the bass is really heavy and making my needles jump. And the sound waver. This doesnt normally happen unless there is loads of dust on the vinyll. New vinylls on for the show. Running side b on ssl 02 s and never normally have this problem. Any ideas or tips much appreciated.
Thanks
Thanks
geposted Mon 15 Nov 10 @ 2:23 pm
Put a block of foam under your turntables to absorb the bass thump.
geposted Mon 15 Nov 10 @ 4:31 pm
how did u make out?
geposted Mon 15 Nov 10 @ 4:51 pm
