just need a bit of help i have an advent 6552 laptop, what i want is to play the music out loud through laptop speakers while headphones are plugged in , so i can mix with the headphones. i know this is possible because ive done it before but formatted comp since.
im a bit of a noob when it comes to soundcard details etc.... i have changed few options in sound setup but cant seem to get it
also dont know if this is possible and if im allowed but can anyone resize a skin for me ??? its the Pioneer CDJ-2000
i need resized to 1440x900 cant get any decent skins to fit my screen as its a 17" widescreen
geposted Wed 17 Nov 10 @ 4:06 pm
You won't get any sound from your laptop speakers if you plug headphones into the laptop.
Any standard laptop will cut off the audio to the onboard speakers when headphones are plugged in - that's normal.
The only way to achieve your goal would be to use an external sound card or USB headphones (which act as an external sound card) and feed the main output to the laptop speakers (not good as the sound quality will be terrible) and the cue output to the headphones or external card.
geposted Thu 18 Nov 10 @ 6:08 am
