hi all.
are the databases in vdj compatible with numark cue. what i mean is, is it possible to transfer the database from my vdj to the database of numark cue?
if so, is it just a case of copying the vdj d/b into the numark cue d/b, or is this just wishful thinking???
thanx in advance.
thanx in advance.
geposted Thu 18 Nov 10 @ 3:55 pm
I am not sure, but it sounds like it will work. Try it and let us know.
geposted Thu 18 Nov 10 @ 3:59 pm
As long as the version of the software is the same then it will work no problem.
Not sure if the Cue DB has a different name, if so rename the file.
Also remember to backup your current DB in case anything goes wrong.
Keith
Keith
geposted Thu 18 Nov 10 @ 4:11 pm
Keith
hi keith, they are different versions......do you know if there is any way i can obtain an earlier version of the numark to make it compatible with my vdj?
Keith
geposted Thu 18 Nov 10 @ 4:34 pm
