when i listen the next song on my headphones and play a sampler it play on the headphones too it's any way to avoid this... or it just the way it is..?
geposted Thu 18 Nov 10 @ 4:52 pm
If your using a mixer with more then 2 channels just assign the samples to there own channel.
Huey
Huey
geposted Thu 18 Nov 10 @ 5:48 pm
thanks man now how do i do that?
geposted Thu 18 Nov 10 @ 8:11 pm
Huey's got a cold rite now..illin way too much..lol...huh...you go to advance cofigirations of course,then select a new output there,you should see your other outputs available and sampler on the "Drop Downs" then select...easy.
geposted Thu 18 Nov 10 @ 8:44 pm
If you have a 3ch external audio mixer, you will probably need also a 3rd stereo output to route the sampler to the 3rd channel of your mixer.
In order to guide you further, you will have to inform us about the hardware you use.(controller, sound card(s), external mixer, etc)
geposted Thu 18 Nov 10 @ 10:03 pm
thanks dj dad this my set up
i used the djio just to be able to listen the next song.the djio is connected to one channel from my mixer (5 channel mixer).and i control VDJ with the total control i only use the mixer for the mic and volume of the music.
geposted Fri 19 Nov 10 @ 5:11 pm
So the only available sound card is djiio ? I am afraid there is no output chanel left, so try to use your laptop sound card. Route a cable from yout laptop audio output to one free channel of your mixer and then go to the advanced audio config and add..
Sampler ... Laptop Soundcard ... Output 1&2
This way you will hear the sampler only from the chanel of you rmixer you have chosen.
geposted Fri 19 Nov 10 @ 5:18 pm
I don't think that soundcard is gonna work. You need atleast 3 outs. I suppose you could use splitter and try using it in mono mode.......
Huey
And he slips in again.............nevermind what I said.
Huey
this works but now there is a distortion in the music:
Master = djio
Headphones= djio
sampler= laptop sound card
the sampler sounds good but the music plays with distortion.
geposted Fri 19 Nov 10 @ 8:57 pm
You mean if your setup is like this ..
Master = djio
Headphones= djio
you dont have any distortion ?
I am not familiar with djio, but i think that has 2 stereo outputs? right?
So in the Advanced Config set..
deck 1 .. djio .. output 1&2
deck 2 .. djio .. output 3&4
Sampler .. laptop soundcard ..output 1&2
This should work. Of course you will use haedphones from the external mixer not the djio.
Master = djio
Headphones= djio
geposted Sat 20 Nov 10 @ 7:43 pm
The distortion came out because you're not using anymore the ASIO instead the 2 cards config., in WMD mode.
As per djdad, go to advance config:
Master = djio asio
Headphones= djio asio
And if there's still glitches with the audio, you can simply adjust the DJIO asio settings on the DJIO panel.
Master = djio asio
geposted Sun 21 Nov 10 @ 2:31 pm
thanks to all of you guys for the help.... i tried all the settings you told me but still can hear the sampler in the headphones
geposted Sun 21 Nov 10 @ 8:06 pm
the way that i do it is pretty easy and its worked perfectly for me
ive got my main line running through my headphone jack from my computer to my speakers. then got an external sound card, and i have my headphones in there. then under the vdj settings, i say that i have a main output and a headphone output, and set the headphones to the 2nd card. then it works perfectly. on my hercules mp3e2 i can select to listen to either track and its independent from the main output
geposted Tue 25 Jan 11 @ 12:04 pm
hi guys, right ill try to explain this properly. when i prelisten with headphones to next song on deck 2, is there a way of trying samples with that song on deck 2 without it playing through main song on deck 1.
geposted Thu 26 Jul 18 @ 7:34 am
Yes send the sampler output to deck 2, sampler options.
Or any deck other than 1 with pfl on and the upfader closed.
geposted Thu 26 Jul 18 @ 9:30 am
See this Video https://virtualdj.com/totd/5/
Manual : https://virtualdj.com/manuals/virtualdj/interface/browser/sideview/sampler.html
You can even have shortcuts to assign Sampler to either Master or some specific deck.
deck master sampler_output
deck 1 sampler_output
deck 2 sampler_output
etc
etc
geposted Thu 26 Jul 18 @ 12:37 pm
