Hey their guys. I wanted to know if their is a way to hook up an ipod to the Hercules RMX? Well on my first and only gig so far I ran into a lil problem The client had hired some hula dancers and they wanted to hook up to my sound so they didn't need to use a little boom box. and I told the client thats fine but i'm not sure how i would hook up unfortunately I had a little 5 channel mixing board that i was able to use for them but I had to pull out the main 1/4in from the RMX and plugging in to the lil board. So at the end of the night I gave them some business card to pass the word around for me. So the other day the lady email me and wanted to kinda come together and work together as a duel business, So thats a plus for me but I wanted to know if I can hook up for them with out shutting down completely to change over to the mixing board for.
thanks
steve
thanks
steve
geposted Thu 18 Nov 10 @ 5:54 pm
steve , get some mini plug to rca wires at radio shack and get some 1/4 in adapters for the rca's
now you can plug any device with a mini plug output into any 1/4 in or rca inputs
i take it all the inputs were in use on the mixer , so you had to unplug something ?
geposted Thu 18 Nov 10 @ 6:17 pm
Yes. I have the RCA inputs cable now bred to find out if I can plug in to the RMX so I don't have to unplug the main speakers from RMX to the little mixer. Wanted to know if I can do with out the small mixer?
geposted Thu 18 Nov 10 @ 10:22 pm
if your using the rmx as the mixer for the client..you should be able to run from 1-2 or 3-4 and use the source button correct? or did i miss thaT all channel options are being used?
geposted Fri 19 Nov 10 @ 9:18 am
steve .....there are 2 kinds of inputs , line level and phono
phono , of course is turntables , line level is cd's , mp3 players , computer , boom box , cellphones ......
all those things that have mini plug outputs
so , if you wanted to , at home you could experiment hooking up a boombox or mp3 player and try that out
your mixing board and RMX , don't know or care , if it's an ipod or a boombox or a phone ......
just set the input channel to LINE and it will work ....
as far as your set up goes .... if you are already maxed out , unfortunately , friend ,
you probably need a bigger mixer ......
please give us more details about how you have this hooked up , don't assume we know things that we
couldn't possibly , and spell it all out
geposted Fri 19 Nov 10 @ 10:10 am
Thanks.... I will try playing with it. All my inputs are free at this time except the 1/4in inputs for the speakers. I'm not using any other devices at this time on the RMX..
geposted Fri 19 Nov 10 @ 10:23 am
i hope that was some help ...
what is at least a little confusing for me , is i only use the RMX as a controller.....
so i don't use it as a mixer .....
look , you like the RMX , i like the RMX , lotsa DJ's like it .....
but, it's a soundcard , plus a controller (MIDI) plus a mixer .......
so ..... if it were state of the art , in all 3 areas , then WHY doesn't it cost say, $3000 ???? or more ??
the point is , don't get rid of your mixer .....
if you can concentrate a few different things onto the RMX , that's good , they aren't using up
inputs on your mixer , and your mixer is a much better mixer than the RMX .....
you must have done a very good job for those hula babes , under trying circumstances for you ....
proud to know ya .....
if you are friendly , accommodating , and don't speak technological gobbledy gook , your customers
will like you a lot ......
my attorney ( Smedley Screwyoualot) said i should charge for that advice .....
so that'll be 59 cents .......
geposted Fri 19 Nov 10 @ 10:36 am
