im pretty sure its real simple to figure out my help issue which is i want to play music out my speakers from one deck because im using 4 decks and with the other three i want to be able to hear those 3 decks from my head set so i can mix them into the 1st deck you get what im saying i hope so please help.
geposted Fri 19 Nov 10 @ 10:43 pm
To be able to pre-listen to music using headphones, you will either need two sound cards or a sound card with multiple outputs, such as a 5.1 surround sound card or preferably a dedicated DJ sound card (E.g: Numark DJIO or Native Instruments Audio 2 DJ.)
With a laptop, you can add a USB stick sound card that will provide you with the additional output that you need.
Alternatively, you can use a single sound card and the mono split option in VirtualDJ's sound setup, however this will only give you MONO sound. You will need a splitter cable to split the left/right channels - Please search Google for: 3.5 jack splitter to mono
Once you have suitable sound card(s), you will then need to go into VirtualDJ CONFIG -> Sound Settings and choose Outputs: Headphones and select the appropriate sound card(s).
To choose which deck to pre-listen to, press the TAB key. Use the crossfader and/or volume sliders to control which deck is output live over the master outputs.
geposted Sat 20 Nov 10 @ 1:15 pm
