Is there any EASY way to swtich between all 4 decks using only 2 timecodes?? IE 2 decks for each time code.. right now you have to hit the deck, turn off time code, hit the other deck and turn on time code.. is there a shortcut or a quick on-screen button I can create or use? at a gig it takes too long to switch timecodes when mixing live..
geposted Sat 20 Nov 10 @ 11:03 am
Here map a button with this,
"deck 1 timecode_active on ? deck 1 timecode_active off & deck 3 timecode_active on & deck 3 rightdeck & deck 3 select : deck 3 timecode_active on ? deck 3 timecode_active off & deck 1 timecode_active on & deck 1 rightdeck & deck 1 select "
and map another with this,
"deck 2 timecode_active on ? deck 2 timecode_active off & deck 4 timecode_active on & deck 4 rightdeck & deck 4 select : deck 4 timecode_active on ? deck 4 timecode_active off & deck 2 timecode_active on & deck 2 rightdeck & deck 2 select "
I sat on here with DJ-IN-NORWAY for like 3 hours going back and fourth until he came up with these, its perfect!!
Huey
Huey
geposted Sat 20 Nov 10 @ 11:08 am
