Hi there. I know this question may have been asked time and time again, but i have the following setup
2 x technics DZL1200
1 x numark 3 channel mixer
1 x maya 44 usb soundcard
now ive been using cds since the time i started djing and now i recently got given this soundcard to try out.
im confused on how to set up everything. eg where do the rca's go etc
so if anyone could kindly point me in the right direction i would greatly appreciate it.
ill be running the trial version of virtual dj to see how i like it.
any help would be so useful.
thanks
thanks
geposted Mon 22 Nov 10 @ 4:15 am
the short and simple version- not to tech:
each TT goes to the in's on the 44
then take the same corresponding outs- ie the left TT and the rite TT and match them to a channel each on the mixer, \
that gives you your tt to mixer set up. run the usb to your computer
inside vdj if using a valid trial version of vdj 7 you will get a 20 min increment of use
goto config run vdj
input 2 tt
output external mixer
soundcard maya 44
you can substitute tt for cdplayers or tt.
goto config run vdj
input 2 tt
soundcard maya 44
geposted Mon 22 Nov 10 @ 7:40 am
