I'm looking at new PCs for doing video DJing. I'm sure spec wise, this particular PC is more than adequate, but know in the past particular video cards were recommended. I can't find current recommended system specs on the site. Can someone please tell me if this laptop will shine while mixing a video show? Pairing with 2 Denon 3700s which will also be the sound card(s).
Video Graphics ATI Mobility Radeon HD 5650 graphics
Video Memory 1024MB DDR3
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02496909&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
geposted Mon 22 Nov 10 @ 7:01 am
The specs look good other then the 64 bit os, 32 would be less likely of problems, then you have the installed bloatware that may also present some issue, but it could be an off the shalf winner..you just need to be remove and tweak ready if need be..
Good Luck,
Joey....
Good Luck,
Joey....
geposted Mon 22 Nov 10 @ 8:17 am
Can you get a 32 bit OS anymore? What kind of issues might a 64 bit OS present? I'm no stranger to tweaking but...?
geposted Mon 22 Nov 10 @ 8:22 am
Just make sure your controller (if you use one) has 64-bit drivers. VDJ runs fine in a 64-bit OS.
You can always buy a 32-bit OS for about $100.00, if for some reason you decide too.
geposted Mon 22 Nov 10 @ 8:31 am
Mostly video issues, but there are workarounds and tweaks available, the forum threads are full of them, soo you should be OK...
Good Luck
Joey...
geposted Mon 22 Nov 10 @ 8:40 am
Ok. Just want to be sure this will be smooth with video scratching n such because the system I have now does fine with audio but not video. Need to be sure...
geposted Mon 22 Nov 10 @ 9:00 am
gents , i have been using 64 bit for well over a year on Vista and W7
don't forget with 64 bit you can use powerful systems with lots of ram , 4 gigs and up
if you get W7 , optimizing it is similar to what you would do in XP
geposted Mon 22 Nov 10 @ 12:03 pm
Thank you.
geposted Mon 22 Nov 10 @ 12:28 pm
