Hey everybody!
I'm using VDJ without any hardware and wanted to know if there's a way to start one deck whilst simultaneously stopping the other with one button/function?
This way, a song with a nice hard intro could start without having to move the faders on the previous song (which is a bit fiddly using a mouse/pad!)
Hope this makes some sort of sense!
Love to hear your thoughts
Cheers
Mark
Cheers
Mark
geposted Mon 22 Nov 10 @ 3:27 pm
im not good at scripting but i think if you give it some time the others will help... also double post is sure to get one of them locked
https://virtualdj.com/forums/137938/PC_Version_Technical_Support/Any_suggestio.html
geposted Mon 22 Nov 10 @ 3:41 pm
Thanks very much for that :-)
geposted Mon 22 Nov 10 @ 3:55 pm
Hi,
Try assigning the following script to a keyboard shortcut, it effectively "chops" from one track to the other with one key stroke
deck active pause & deck default play & deck active select
Hope this helps!
Keith
Hope this helps!
Keith
geposted Mon 22 Nov 10 @ 3:57 pm
Keith you legend!
Works a dream!
Cheers mate
Works a dream!
Cheers mate
geposted Mon 22 Nov 10 @ 4:11 pm
No problem, glad to help.
Regards
Keith
Regards
Keith
geposted Mon 22 Nov 10 @ 4:14 pm
