From VDJ6, I see the included mappers in Documents->Virtual DJ, but I can't find where the mappers are that come with VDJ7. Can anyone help? thanks.
geposted Mon 22 Nov 10 @ 9:36 pm
Mappers are included in the software. But if you make a small change in any button of your controller, the mapper will appear in VirtualDJ/Mappers folder.
If you want to see all the supported controlers, goto config, mappers, there is a button (mapper options) next to the drop down list. Click, then unselect the ... show only connected devices ..option. Then you will view all the devices in the drop down list.
geposted Mon 22 Nov 10 @ 9:39 pm
