The situation is kind of annoying and already made me look bad live...
I use a lot of loops, acappellas on the sampler slots.
The error happens on a particular situation:
- I'm playing a song on a deck and play a loop on the sampler slot, then i stop the music on the deck and let only the sampler playing, the problem is that everytime i use the sampler on solo (without any music playing on decks) the loop goes simply crazy!
Almost like a pc freezing or using all RAM, the problem is that i've looked up and the processor and RAM are in 10 or 20% tops...
What could it be?
Other question is weather is possible to apply effects on the sampler slots. How?
Thanks in advance.
What could it be?
Thanks in advance.
geposted Tue 23 Nov 10 @ 9:05 pm
Instead of using the sampler, why not use the decks 3 - 6 with the advantage of using effects and everything staying sync'd? It is quite easy to set up the advanced audio. If you want some help just PM me.
geposted Thu 25 Nov 10 @ 12:05 am
