I have a simple Numark M2 mixer and a macbook pro that I will be running VirtualDJ on. The mixer is two-channel. I can't get the two channels to separate when plugging the mixer into the headhpone jack on the mac. After some research, I realized I will need a simple external sound card in order to get these channels separated. My question is this... Say I get this external sound card and plug both L/R channel inputs into the mixer and the external sound card. Will I need a 3rd RCA cable to ouput from the master outputs to plug into the soundcard as well, or can I just exclue that RCA cable completely by just plugging my headphones into the mixer? I found this external soundcard, but i'm not sure if it's going to serve the purpose I want it to. (IKEY ICONNEX PORTABLE USB SOUND CARD ). So basically, i'm just trying to find the simplest way to get my channels to work individually with headphones.
Any help would be appreciated.
geposted Wed 24 Nov 10 @ 11:39 pm
